Oldsansui441
No apologies needed, happy to discuss anything on my thread, it's all interesting stuff
This is very interesting mbz as l thought ripple rating had a direct correlation to ESR, l guess not in this case as the KG's have a higher ripple rating, the larger surface area should also be of benefit to dissipating heat. I have had a good run with the type 2 KG's and l would def use again but your findings with the KW's are very interesting indeed particularly as they are not designed specifically for this purpose, l have no doubt in your findings on your NAD.
This is a valid point zaibatsu, l know what you mean, in all of the different amplifiers l have worked on l notice that with the different designs comes very different power supply layouts, even for a similar rated output. Some have little capacitance on the power supply after the filter caps where others have much more, ie early to mid 70's pioneers.
I compared the datasheets for the KG's and KW's and noted that the KW's had a lower ESR/Tan delta
I think Yamaha amps, particularly the higher end ones use many stages of local capacitance to feed transistors, and as a result, in amps like the one in this thread I would think that the local capacitance makes a far bigger difference. On lower end amps the main filter capacitance is much lower + without running in Class A there is a far more variable load on what is potentially insufficient capacitance - which is why a lot of those low-to-midrange amps have audible benefits with main filter cap upgrades. No doubt for the same reason they are more sensitive to their performance too.
