I could not access that point I removed the board and inspected all the joints and traces couldn’t find anything amiss. Tightened the screw, replaced all the diodes will board was apart and refitted. Now have about 650mv minimum on tp1 and tp2 the dim lights up very bright with no relay engaging confirmed outputs and drivers to be okThe freely available sm is really bad. I should have said measure at TR319b but don't like probing transistors and figured a diode would be an easy find, my bad.
To make things worse, the board layout shows 2 of D910...
Suggest you download the CA-1010 sm, it is an easier read and there are some similiarities.
Can you measure Vdc at TR319b
