Yeah FR703. What is the voltage across it, about 4Vdc?I'm sorry, did you mean FR703?
About 50mA which is fine on DBT.Starts at about 1.2 Vdc then goes up and stabilizes at 2.49 Vdc.
That was on mains. We have been off the DBT for quite awhile now.About 50mA which is fine on DBT.
Assume all B+ wires etc have been reconnected
Time to power up on mains, no DBT, have your MM still connected across FR703, it may spike at power ON but should remain below 6Vdc. The relay will be kicking in at each power up.
NO, I am too afraid.edit
If OK then try connecting speakers or dummy load, continue to monitor FR703 voltage
Back from the Hockey game,That was on mains. We have been off the DBT for quite awhile now.
Try headphones, it's an easier load.NO, I am too afraid.
for my test no source needed to check if any DC is on the outposts.I need to plug in a source I assume?
How will I know if sound is going thru?
Yes !!! You Did it !! Took us all of 15 pages to get it to pass sound .I hooked up my Iphone with an RCA line into Aux1 and no sound then I remembered the Pre Out Main In switch was off so I put it back.
Got sound out of the headphones. Left MM hooked up the whole time and it never went past 2.49 Vdc.
$50 says it will blow up again tomorrow.
I will hook up small bookshelf speakers and maybe a cassette deck and see what happens. I will keep MM on FR703 and monitor.
Thank You everyone for all your help. I will check in tomorrow.
PS it was a very bad day, my beloved Hawkeyes got beat by Ohio State and my daughter is a student at The University of Iowa where the Hawkeyes are from.
I stopped watching the game at halftime.my beloved Hawkeyes got beat by Ohio State
That definitely calls for some whiskey …I stopped watching the game at halftime.
Your psychic.That definitely calls for some whiskey …
Your psychic.![]()
Sake here …Really? Usually you can't remember anythingI remember the last time I drank too much saki.![]()
Really? Usually you can't remember anything![]()
I remember feeling like poop the entire following day.Really? Usually you can't remember anything![]()
Ok here is where you need to monitor the Bias for both channels. One might be higher causing that side to be hotter.Powered her up with cell phone connected thru RCA and she put out music for 10 minutes straight. Left side is louder than the right side and the left output transistors are a bit warmer than the right side. Can't find anything that is supper hot and nothing smoking. MM connected to FR703 the whole time and holding steady right at 2.51 Vdc.
Hang tight for my thoughts on all this. LOL
