¿Dónde compraste los repuestos? ¿Son falsos o auténticos?
I always prefer to keep the original components when making replacements, except in cases where a component is known to malfunction due to design flaws or is simply problematic. In those cases, if I can find them, I usually buy them from a local, generally trustworthy shop that stocks older components. However, I'm aware that you can never be entirely sure of their condition, even if they're new and unused, due to their age.
On the other hand, since these components aren't so specific, I buy from Mouser.
In this case, with the exception of the KSC1815 installed to replace the 2SC485, the rest of the replacement parts are old stock: the 2SC485, 2SA747, and 2SC1116.
Sí, parece que andas un poco disperso. Elige el problema más grande y luego trabaja en él. Olvídate de la clase A hasta que resuelvas lo normal.
¿Los voltajes de la fuente de alimentación son correctos? (Parecen razonables)
OK. It's a great achievement it's given me quite a headache to figure it out.
¿El relé hace clic entre 4 y 6 segundos después de encenderlo?
Yes
¿Tienes audio en el canal reparado?
Pending testing.
I still need to figure out why one of the channels (white cable) has no audio. Something is wrong with one of the sound cards, specifically with the volume, balance, tone, and filter settings
I tried connecting the preamp output of the unit to the main input, but I still don't get audio from that channel.
La polarización de 22 mV (o la que sea) no es un gran problema, así que dejémoslo de lado y centrémonos primero en los tres puntos anteriores.
