Janochytron
Hi,
I got this Yamaha. Decided to do basically full restoration.
Now I read that the two microswitches for ClassA/Normal operation are a weak point and it's a good idea to change them.
What exactly do they do? I can see red and orange cable coming from the transformer. Red brings 30V, Orange brings 13V. When I select normal operation, I can see 30V leaving the switch to the rectifiers. When I select class A, I get only 1V going away.
Thing is, the amp was working before on both operations. But I did not measure the voltages when all was still assembled so i don't know what they were with everything connected and working ( I have removed the volume,filter and tone boards, but that should not really influence these voltages.
Would this be a good replacement?
I found it as alternative to elswhere mentioned V-10-1A4 from Omron.
http://ie.farnell.com/webapp/wcs/st...3&langId=353&partNumber=1796565&storeId=10163
If somebody has done restoration on ca-800 and has a list of what they substituted, that would be much appreciated. Any tips and ideas welcome.
Thanks
Petr
Thanks
Petr
