AngelAT
Well-Known Member
OK, I understand. Thank you!Yeah, apologies from me, it was not a great explaination.
We are trying to work out why the relay randomly releases. One possible cause is a spike in dc voltage. If you look at the sm and dc offset adjustment they ask you to check for 0V at Ro and Lo. Looking at the schematic, you will see that Ro and Lo are after the relay, so all good if the relay is engauged. But if the relay randomly releases then Ro and Lo are no longer connected to the power amps. So working back from the relay you will see a connection at the emitter resistors. So monitor the voltage to GND at this point, xxmV is not unreasonable, looking for a drift or spike into the hundreds of mV. If you are able to "provoke" the fault then that would speed things up.
Will measure and come back
, why not right away?
