Yamaha CA-810 Schematic Issues
[QUOTE = "avionic, post: 14067856, member: 14955"] Are you refering to the green masking? [/ QUOTE]
Today I was probing around on the board using the scope probe with the end removed thus allowing pressure to be placed against the solder joint. I am suspecting this sudden change in voltage may have something to do with the solder trace to the component circle connection. If I could clean that green film back just a little I may be able to place a small spot of solder at that location.
Green solder masking..Off hand I don't know of any solvent that will even touch that coating. Short of scotchbrite pad or sandpaper.
2SA844 - 512-KSA916YTA
2SA872 - 512-KSA992FTA
2SC1213C - 512-KSC1008CYTA
2SC1628 - 512-KSC3503DS
2SC1918 - 512-KSC1815YTA
2SC7340 O-Y - 512-KSC2830OTA
2SA5610 O-Y - 512-KSA1015YTA
2SC1624 863-MJE15032G
2SA814 - 863-MJE1503G
2SD425
2SA679
2SC1775 512-KSC1845FTA
2SD234
1S1555
WZ061 - 512-1N5234B
1S2092 - 512-BAV19TR
1S1885 - 863-1N4002RLG
WZ120 - 512-1N5234B
1S1886 - 863-1N4002RLG
