Hifibythekg
Thanks Avionic.
The phono does have the shorting plugs installed.
But will try AUX to start with.
Thats fine then.Leave it there.The phono does have the shorting plugs installed.
Yes... Do this test with power on?
no .having looked again i can just make out you had it set correctly ... i thought the arrow was pointing to ohms .Thanks Pete.
So the DMM should be set to 750 at 'V wiggly hyphen' symbol?
YesDo you want the power o be switched on?
