Hifibythekg
Thanks!
And leave the DMM on the same settings for this reading? That is 200mV?
It will need to be moved to a higher range 200VThanks!
YesOk to put the grabbers in place, and then turn on the power?
I had the power on when trying to adjust the idle current.
Measure the voltage at the two fuses on the amplifier assemblies.
Is the other fuse a - 49vdc ?Same fuse location on right board is also 49.0
