Yamaha CR-1020 idling current not adjusting
Hey, Ylli, thanks for joining in and offering some help.
Yes, I'm holding on for an inspired solution from Avionic.
Have a good evening.
What did the OEM 2SA844 transistors look like ? Do you still have the old parts?
Yes, these are the readings for the original and replacements.
Just wanted to verify the A1015's were installed correctly.
How much voltage are you seeing on the gray wires on the amplifier assemblies. ?
Caution : There is suppose to be around - 91 volts.
For this, do I place black probe on chassis, red probe on the gray wire on the ampboard?
"How much voltage are you seeing on the gray wires on the amplifier assemblies. ?"
