Gr8One1998
Hey all,
I have a Yamaha CR-800 that I bought a few months ago, and I'm having an issue where the right channel will crackle/scractch, and the sound fades in and out. When you turn the receiver on from a cold state, the sound in that channel is fine, but after a few minutes the symptoms come in. Here are some of the things I checked:
- This occurs on any input (phono, AUX, tuner)
- I've swapped speakers (R to L), and the issue stays with the channel, doesn't follow the speaker
- The issue presents itself with headphones as well
- I've swapped out speaker wire, no resolution
- I've cleaned all the pots with Deoxit, no resolution
- I looked at resistance and voltage at different points between the input section and the speaker terminal, and was not able to find any discrepanices between the L and R channels (I will admit that I'm a total novice when it comes to that sort of stuff)
- The left channel works perfectly
Any ideas what might be the issue here? I've tried to logic the problem out as best as I can, but have hit a dead end. I'm hoping one of you who knows a lot more about this stuff than me might have some ideas!
-Tom
-Tom
