Gr8One1998
OK, I'll take those off and test them tomorrow night.
Whats there part number ?Just picked up a pair equivalent to those from Fry's.
I suppose it it could.. What voltage are you reading on the output transistor collectors. They should be equal voltage one being positive voltage and the other a negative voltage. ie. + and - 35vdc ??
Connect your black test lead to the chassis ground. With the red lead, probe the output transistors case (collector) for DC volts .Be very careful not to short the case of the transistor to the heatsink or you will be replacing more fuses.not sure how to test the voltage off the collector though?
After looking at the board closely again, it looks like one of my fusiable resistors (FR701) has some discoloration on it, indicating possible frying
I was going to say. Check your fuses again. Then check FR701 out of circuit.Got it. The transistors on the left side are showing 45/46V. The transistors on the right side, one is showing 2.6, the other is showing 0.
Pop another one in.
Back to the drawing board. Let me ponder this dilemma.
