Yamaha CR 800 - crackle/fade in right channel
Well it looks like R740. According to the shitty, free, SM downloads. 10 Ω 1/4 watt.
Need to clean off all that smoke soot. And test TR714 driver out of circuit.
Well, I think I may have fixed it. Tested TR714 (and it's PNP partner on the other side of the capacitor), and both were fried. Replaced those, and replaced 3 burned out resistors, and it seems to be working! I'm gonna put it through it's paces for a couple of hours tomorrow to make sure nothing else bursts into flames, but things are looking up!!
Thanks for all your help avionic; you definitely made a HUGE difference to this project!!
Well the good news is nothing has blown/burned up! Unfortunately I'm back to a variation of my original problem; crackly/staticy sound and fading sound. It's a little different than before - originally it was a problem with the right channel, now it's somewhat both.
- Both channels have the issue when outputting through the speakers, and also now when I play around with the volume, the sound cuts in and out when I move the knob
- On the left channel, the issue is present in the speakers AND headphones, but on the right channel, it's only present in the speakers (sounds perfect in headphones)
- I've tried different speakers, and speaker wire, and that doesn't solve the problem
- If I move the TR713 and TR715 transistors on the left side with a wooden stick, it does affect the sound coming out of the left channel, so I plan to re-test those and either replace or re-solder them. That doesn't explain the issues on the right side though
- If I press on the protector relay with the wooden stick, that also affects the sound on both channels
Any thoughts beyond checking those 2 transistors?
I'd be looking at the speaker select switch as well as the headphone jack - Again dirty switch contacts or cold solder connections.
Spray some deoxit on your headphone plug and slide it in and out of the headphone jack a dozen times or so. See if it cleans up the jack contacts.
Re-soldered the relay connections, and notice a bad solder point on one of the transistors, so I fixed that. Right channel seems to be good now, but the left is still giving me a problem. Not getting the same issue with the sound cutting in and out when adjusting volume. The left channel issue is present on both the A and B speaker terminals. The interesting thing is that, when the headphones are in and the speaker selector is OFF, the sound is perfect on both channels in the headphones. If I move the speaker selector to turn the speakers on as well, the issue in the left channel starts to impact the headphones as well as the speaker.
Deoxit D5. After a bit more use, it seems to have helped somewhat, but is still a bit static-y. I'll try taking the switch apart and cleaning it really well next.
