Brad1234
I have a working M-60 amp that I am planning to do a full recap of all electrolytics and looking for guidance on any other parts I should replace or test for best reliability long-term? I will replace the relay and trimmers as well. All of the corrosive glue has been removed and all of the parts affected by it are still in spec, but will be replaced anyway, just 2 1000uf caps and 2 22ohm resistors were damaged a little.
I have read thru the other posts on this model and nothing jumped out as being recommended to replace other than the electrolytics, but this unit is now 40 yrs old and wanted to get a current reading from the experts on it before ordering all of the parts. I have a lot invested already since I did bite the bullet on the (4) 33,000 uf/50v CDM 383LX main caps already. Any help will be much appreciated!
Is there a trick to getting the wire harnesses unseated from the board, they seem to be seated in there pretty good and I tried pinching them in various ways to release them with no luck. Attached are some pics of the amp.
