Yamaha M-60 amp restoration planning
Doesnt affect the sound and will propably last for another 40 years, that's my point.
But replacing them will give one peace of mind, for sure.
They have to hover in the brackets since there are so many connections on the board under them I guess.
Looking good. I used the same main filter caps on one of my 60's. The hover space between the new caps and the board bugged me; feared they would slide down over time. So I put some Loc-tite blue on the bracket cinch screws & crossed my fingers.
Any suggestions on where to buy the type of hook up wire/braid
I purchased solder wick/copper braid at our local ACE hardware store, lol. Had a decent electronics section for a chain hardware store.
Edit: I put heat shrink tubing around the solder wick braid cuz the sight of bare copper flopping around bugged me too. Again, just things I do/did.
I left the main caps alone on my first couple M-60's. Figured I'd milk them 5-10 years. The one I did last winter though got the same CDM's the OP is installing now. I noticed some better bass, better all around. But man, it was a booger installing them. Glad I cut the solder wick in 6 inch strips. Had to have my son help me fish it through while I held the 4 bracketed caps.
Stock was low last winter so I bought the OP's caps and the larger CDM's, wasn't sure which to install at the time. Installed the smaller ones and they rock. Get em while ya can I guess.
I'd rather share my experience with a side of hint than than get too opinionated about main filter caps. I do know the internal electrolyte dries out from time & heat, and still may "test ok". One day those old caps will spill their guts without warning so I'll be slowly swapping them over the next few years in the 60 hoard, lol.
These big suckers will go in one day...
I have an idea for the main caps to help support them, I am going to look for some of those nylon spacers in nuts and bolts aisle at the Home Depot just long enough to be a center support beam under the middle of each cap to help with any sliding. The new caps are a tiny bit smaller than original and slip a little in bracket even fully tightened. Will need to cut a thin strip of rubber shelf paper/neoprene or electrical tape to add around cap to make clamp hold tighter. I plan to use 16 awg solid core copper wire to make the around 1” distance need to reach board. That is my plan so far, will get some pics when parts arrive and get back to the restoration.
I have done lots of main cap replacing and swapping and they have always had a huge impact on overall sound quality. Speaking of some giant caps, these are in a Parasound HCA-3500 amp I am perpetually working on trying to fix a bias stability issue. They are same 33k uF but 100v, but much larger than my new CDM caps.
I'm considering this on the next one if there's too much play between clamps and new main caps...
2 sided sticky rubber tape jones
Just a small chunk as needed not the whole mud spray roll, lol.
Any thoughts on some permatex black around the clamps?
A couple dots of some good black adhesive at the seam behind each cap would probably be enough to prevent any slippage down. I found a 1/8th inch thick neoprene rubber sheet on amazon for $20 to cut some strips to add to the clamps for extra grip for the smaller new caps. Here is a pic. It is handy to have for other uses of padding and insulating stuff in other electrical projects too.
I wonder if the Japanese engineers back in the day ever imagined we'd be holding these pieces together today with roofing material? :biggrin:
My 60's work fine with it so far & no chipmonks get in yet
:beerchug:
I have an M70 that I fixed but did not restore it yet, still working on my B-1 , that amp intimidates me :(
I have a working M70 that needs to be restored too. Post up when you do please. X Power intimidates me some on this one. I'm just getting back into this after moving interstate and setting up my bench again. Still in the middle of rescuing a B-6 that was physically damaged and someone tried to repair and pulled the triac and other stuff.
Update on progress, I have all of the electrolytics replaced and been struggling with main cap replacement. I decided on 16 gage solid wire to connect 2 tiny negative and positive solder points on the 383LX 33k uF Cornell Dublier main caps. So annoying how ridiculously the small the solder attachement point they provide.
My solution was to use 16 gage solid wire to bridge the 2 tiny solder points on caps and use a 3” piece of 14 gage stranded wire with tips tinned with some solder to allow for easy feading into Yamaha board.
I knew that would be a bitch post #53 brotha.
Solder wick braid Jones
This rebuild was challenging for me and I have done a lot of restorations. This Yamaha board design around the main caps is just crazy. I am sure a lot people will have easier solutions after the fact, which I welcome.
