Yamaha M-80 Protection/Restoration
Before setting the idling current, you’ll need to put Tr143 and its peripheral resistor and capacitor back in … just a reminder.
Hahah yeah i threw them back in last night before i finished up otherwise i probably would forget. I also changed that cap while i was in there. Used a 100v 10uf i had.
So the resistor reads 10k on the color code so i’m going to assume it’s correct. I was easily able to set the bias to 15.5v HOWEVER, i do not get a bias increase of 31mv when going into class A. Hopefully this is related to my problem. I see the class A area on the main amp board. Should i start checking transistors there? It occurs on both sides. Right channel goes up 5mv left goes up 2mv when in class A.
I hope you meant millivolts...
Check all 8 of the emitter resistors & base resistors preferably out of circuit..
I wouldn’t worry about Class A bias until the amp is out of protection in normal Class B operation. Do any of the voltages look different after setting the idle current?
yes i meant mv lol. I was hoping the Class A issues could be tied with the protect.
Voltages seem the same TR143 has E 89v C -.98 B 89.1v so roughly the same as before
I overlooked that minor detail.. opps ..
I've been slinging solder at and M-85 and a C-70...
+L.B voltage has to wait a second.
I pulled all 8 emitter resistors thought 2 tested short put them aside. Installed the rest, tested them again. No short. Put them in and now my dbt lights up bright.
So i believe At least one of my emitter resistors is shorted, but where it was it wasn’t causing a direct short. After i put it back in (in a different spot) it is now a direct short.
I’ll replace all 8 just to be sure. Sometimes my leads measure 2ohm sometimes they measure 0ohm. i should probably get a nicer DMM
Unlikely... The resistors are 0.22 Ω most all digital multimeters will read around .7 to .9 Ω. Subtracting your test lead resistance will get you closer to 0.22Ω
Usually when emitters go bad they burn " open ".. Your test leads probe tips may just be dirty.
Mine reads .4/.3 on them all except one that reads .2/.1 then I touch my leads and Measure .1
Not sure why else I would have a direct short after reinstalling them. No solder bridges
Change them all, also make sure there’s no short with them removed somewhere else along the traces.
It wouldn’t hurt to get a nice DMM either, everything relies on accurate data.
After I pulled one of the pairs the short went away.
This is what’s strange to me about my readings
To determine a short, I’d use the buzzer function. To get that, in the same dial position, press the function key twice. The DM will beep if you have a short …
sadly my dmm buzzes with anything under 1ohm so they all read short that way :thumbsdown:
