Yamaha RXV transformer problem
Verified that the bridge rectifier is good........main caps are good.........damn.
Armed with the new info, I'll keep pluggin away. Thanks for the replies.
Very difficult to isolate trouble on these. It would be nice if you could get power through the unit by eliminating the bad board/unit. I've checked every transistor on the main output boards several times as well as all the emitter resistors. The regulated board looks good too. There are no tell-tale signs of distress anywhere. I checked the protect circuit too.......voltages are per spec......5.7v on the output of the VR & about 5v at the other check point.
Any ideas/angles on how to isolate further? I'm all ears.
See post #16, the wires supply the +ve and -ve rails to all(?) power amp channels. 99% sure these would be wire wrap, again
never undo. Would be great if they were a plug of sorts. Otherwise might need to unsolder post from board but that's a
last resort thing. Should also look at other end of wires (on main electrolytic board) maybe unplugable there? Trying to
confirm problem is with power amp.
No, those are soldered into the boards on both ends. As I mentioned before, I cut those leads & added male/female spade connectors in the middle (there was enough slack) for isolation purposes so as to avoid having to solder/unsolder possibly several times as that can end up ruining the tracks. Those leads feed power for five channels. There is another, slightly smaller, board that feeds power for three other channels (including center) that has a pluggable lead on that board itself. I've unplugged that a couple times with no change, & I've checked all the transistors on that board.
That's what's frustrating. It's hard to isolate what part of the unit the trouble is located in if ALL parts of the unit have to be working in place to get a "power= on" condition, ie I can't check voltages on the regulated board if the power amp board is disconnected (& vice-versa) because the unit won't allow power to flow unless EVERYTHING is connected & working.
This is not a valuable piece of gear (anymore). It's certainly worthless if not working. It was a nice unit in its time, & I'd like to fix it if possible. But I'm also using it as a learning tool. I've been through about a dozen pieces of vintage gear so i'm not a complete novice anymore, but I also know my limitations. That being said, I'm considering bypassing the relay so i can check sections one by one. Yes, I've been using a DBT this whole time, & I believe I can "safely" perform this function (hopefully not some famous last words). Unless I can prove what's good & what isn't, it's impossible to fix it.
Run a test without DBT, the DBT will affect psu voltages which the u-com may interpret as a (low) ps fault.
Isolate power to the 5 channels via spade connectors, centre channel connector still plugged in, assume this still fails.
CB8, pg 79? I saw that but wasn't comfortable removing it because the B- also feeds Q4 setting VP (Voltage Present?), will
look further. Maybe problem is with one of the centre (3?) channels
EDIT: Yeah, that VP pin needs to be correctly set as it goes on to set PRV. So need a
way to disable power to the +/- rails of those 3 channels but also set VP high.
Yep, CB8......it's a PITA to get at to unplug. That's what's frustrating.......eliminating one piece whether it's good or bad disables the relay.
My thought is that I can easily jumper across the relay, have only the transformer leads for the regulated board connected & check all the voltages on that board. The leads are fused on the board itself so if there is a fault there's some modicum of protection. Then, providing everything checks out, I can move on & do the same for the amp boards.
But I'll reassemble this thing & try w/o the dbt first, just to verify.
Thanks for your help........I appreciate it.
What's the idea with jumpering the relay, are you talking about the audio relays, would allow you to measure at spkr posts
or are you talking about the psu/high voltage supply, this may be risky in case of a short. Good approach to use the amp
as a learning exercise. Makes vintage 2 channel amps look real easy...
Yes, I was talking about the PSU relay. I figured with only the regulated board connected I could at least check it.
I put it back together & checked it. There are signs of life.
With the DBT connected, you can hear the relay clicking while the bulb flashes fast, like an old broken turn signal on a car.......on/off repeatedly & never stops.
When I go straight into wall outlet (actually through surge protector) it comes on briefly........about three seconds, enough that the front display lights up & I can change volume setting before it clicks off. But I hear a clicking sound....... more like a thunking, not a relay type of click....... near the main output board heat sink underneath the regulated board. Starts out rapidly...slows......then the PS relay clicks off. There are no relays down there.
Puzzling indeed. Long shot but try measuring dc voltage for each channel "between clicks", hopefully one channel
will be different/odd man out. EDIT off DBT
I think you may have nailed it there. I checked every speaker output during a cycle & it appears as though the "rear center" channel was popping some DC. Hard to know how much because as soon as the speaker relays click on the unit shuts down. But it makes sense as the OPT's for that channel are right in the center of the heat sink for the 5-chan amp board.
I'm gonna go through that circuit thoroughly & see what I find.
Here's what I found. In checking the RCC (rear center channel), I found that by monitoring across L8 I could verify that there was a DC surge that wasn't happening across L4 or L7, the coils for the RRC & LC. I started working back from the OPT's, thru Q67, & so on. When checking Q47A, as soon as I pushed the "on" button I heard a buzz & the unit went dead........the 10A fuse on the standby board had blown.......& Q47A, Q47C, & Q59-60 are toast. I'm 95% sure I didn't short the lead as I was resting the test lead on the transistor (other lead clipped to chassis) before I turned the power on.....never heard a pop or saw a spark. I'm "assuming" that Q47A was the culprit.
Now I gotta look & see what I got on hand for transistors. Pretty sure I'll have to order the OPT's. Meanwhile I'll check all the other components in that circuit.
BTW.........the "thunking" I heard before was the fan kicking on. I had the unit resting on a towel with the bottom removed.
Thanks again for your help, mbz. I'll be back when I get some parts replaced.
Still workin on this thing. The drivers were the 2SC4883/2SA1859 combo, which is different from the schematic. Very fast.....120Mhz. Mouser didn't have them, & I don't have an acct. with digikey. After searching I found that the MJE15032/33 combo is a valid sub for these even though they're only 30Mhz, so I went with those & the MJW3281/1302 combo for the OPT's. But alas...........didn't fix it. Still getting a shutdown after 2-3 seconds & still seeing a little DC spike on the bad channel.
The only other discrepancy I've found is that R158 (base of Q60 OPT) is measuring high.......7.1 ohms instead of 4.7. All other 4.7 ohm base resistors are very close to spec, so I gotta find a replacement for that. Not sure if that's the problem but I can't find anything else at the moment.
I replaced the suspect R158.........still no go.
I decided to start this up on "protection bypass" to check further..........& find nothing abnormal for DC offset. The worst offender has only 20mV........& it's not the channel I've been working on, lol.
But the code reads "DC PRT: 000 C" which I assume means it's still seeing something it don't like.......perplexing.
Understand the code. PRT is protection fault. DC means it's a DC voltage problem and usually the amp, but not always. 000 is the voltage code threshold displayed in % based on 5v. It should return the proper value when all is well, but 000 probably means no voltage somewhere. When working there is a "set" parameter to meet for the "OK" signal for the CPU to power up. The C is a version code. A "PS" code would be the power supply. However I repaired an RXV675 that had a DC PRT code, but it was a bad film cap in the standby board spiking a DC voltage. I believe it was a 0.022uf. Changed it and all was well. Also, sometimes a reset is needed to clear all fault codes. Some codes MUST be cleared or it stays in PRT mode even after repaired. Since you don't know what caused the fault to begin with, try a reset. It could have been caused by a shorted speaker or something else.
  • Like
Reactions: mbz
There also might be an open fusible resistor that protects the CPU, therefore it is not able to detect the DC voltage. I also read a few times where some people had bad diodes on the CPU board causing erroneous DC PRT errors. Their solution was to replace them with 1N4148 so check them too on the DC detect line.
Thanks for the reply. I got the gist of the code through reading the SM. It's about 120 pages & I never thought I'd read half of them, lol.
I'll try the reset next.......I was planning on resetting after it was fixed anyways.
Reset changed nothing.......still got the same code.
I checked the PRD lead.......getting .370vdc @ the pin on conn #510, which is low according to schematic (says 1.2v)..........but then not many voltages are "spot on".
That's almost a volt difference, and in this case too far off. But it depends on what "mode" the unit is in. The voltages in the schematic are measured during certain conditions. For instance, a voltage reading may be during "on" mode, or in "stand-by" mode and will be different.
Which makes this all the more fun to troubleshoot. But this is how one learns I suppose.
  • Like
Reactions: mbz
