RTA of the clearance-sale 18 Sound XD120, 1 meter on axis:
I moved the waveguide back from the front of the baffle approx. 1/2 inch for smoothest full range response as shown.
Info on driver/waveguide here:
http://audiokarma.org/forums/showpost.php?p=2325827&postcount=2948
I finally finished by EWave. I have been disappointed with my recent purchase of a set of JBL 46710K Cabaret Speakers. The 4671 is not intended for home use but I have read that some people are using it at home. On both my Fisher 500C and 300B SET tube amps, it sounds slow with no highs and muddy bass. On the Fisher, the bass is surprisingly absent.
I just happened to start reading this thread around the time Wayne started contributing and found that RussellC had been Ewaving a similar system with great success. I was still very sceptical because I can't see how the mid and bass could be improved.
Well, I finally had some time to do the crossovers the Ewave. I tried it right away after finishing wiring up 1 crossover. Wow, the change is phenomenal. Just as Russell said, the bass on the 2225H 15" woofer is fast with slam and clarity. It goes pretty darn low and this is with a single ended 300B amp. The clarity of the mid is much much clearer than the JBL original. The high is detailed and surprisingly smooth. I do notice that on some LP's I have to tone down the highs a bit via the LPADs. Overall, the integration of the Ewave into this system is pretty much seamless. Btw, I use the Hi-Eff version of the schematic.
Thanks to Zilch, Jack, RussellC, Wayne P and the rest of the gang for having such enthusiasm for this project. Thanks also for sharing your knowledge so freely.
Thanks Everyone. Dave, the bottom horn is not connected. Although it's made of some kind of plastic, the quality is very decent. Maybe the stock crossover is old or is designed for PA duty, but it just doesn't sound too good for home use. I have heard the 2235H at a friend's house and it does sound as delicious as Russell said. It goes noticeably lower than the 2225H. Russell gave a very good description of their differences. I would try to find a way to use your 2225H. Be on the lookout for the JBL 4507 cabinets (that's what I and Russell use).
Russell, I might try to find a pair of 2235H but won't be converting the 2225H anytime soon. I really like the configuration as it is. After I enjoy this configuration for a bit, I'll try out the 2426J (8-ohm) currently mounted to the horns just to see if it has potential. IIRC, Zilch mentioned that the driver could be removed from the horn by unscrewing it from the adaptor. Is this correct? I tried but it is on pretty tight and I don't want to break the horn throat.
I am using the Eminence's ASD1001, and the PE 12" round wave guide. Put those with a Marantz 22 series reciever and it should sound pretty good. Cheers.
Hi D
Have you tried PE12" before? I am thinking about trying them out as well.
Skywave, which Ewave xover an compensation network did you use for this?
How do they sound to you compared to others you've heard?
Hi Kegger.
I'm home today where I have D210s, 6x6 and 8x8 PT waveguides, my 220s and 6 1/2" x 12" waveguides are not here right now. So I can set up the 210 on the smaller waveguides and compare to the 18 Sound XD120s today.
I have standard Econowave x-overs with LPads, the less-than-95dB-efficient version.
In the RTA pic, the top image is raw response, amp directly to waveguide excepting 33uF protection cap in line.
The other uses the E'wave crossover.
