Earl Geddes's measurements of the the EconoWave polar response are now posted on the GedLee website:
http://140.174.80.168/downloads/Horn VS waveguide.pdf
[With commentary....
The Geddes results are not honest results. That is a bold claim, but the data support the claim.
All it takes is a comparison of the NON-Eq'd charts with the EQ'd charts to see that Geddes has EQ'd his waveguide to present optimally, while leaving the JBL waveguide to present less than optimally. The end result is an optical illusion that portrays his product to be superior. Let's explore the results.
Geddes game 1: EQ
a. Add 20db EQ to the top end in order to present a flat response, but not mention it.
b. EQ out the bump at 15k, so frequency response appears flat
c. EQ out the bump at 2.2k, so frequency resonse appears flat
d. FAIL to add similar EQ to the EconoWave 1k-1.6k. Off axis repsonse in this region is almost perfectly decreasing for the EconoWave, but the whole level is just low.
e. FAIL to use EQ to fix the bumps that are constant in their off-axis response on the EconoWave. The bumps are 6khz and 12khz are two examples of non-linear frequency response that can be EQ'd out to make the system present best, but Geddes did not EQ them out.
Geddes game 2: Fail to mention the 5db suckout on-axis in his design. Every now and then, people may find themselves on-axis when listening to speakers in the home environment.
Geddes game 3: More EQ. The frequency response from 600hz-1khz has been EQ DOWN on the EconoWave. The unEQ'd response was down ~12db before he added the EQ, but then it was down ~18db after he added the EQ. This makes his waveguide APPEAR to have a lower point of controlled directivity.
I suppose more observations will be made as people study the results, but at this point, my conclusion is the EconoWave/JBL waveguide is almost as good at maintaining directivity control as the Geddes waveguide, yet the EconoWave doesn't suffer from the strange artifact of on-axis suckout. So, all this considered, I don't see a clear performance winner here.
