Wayne Parham
One more thing, then I'll leave you guys alone.
Let me throw out an idea, a fun thing to do with your PT-F95's.
Some of you have been talking about three-ways. A straight sided midhorn provides reasonably constant directivity and is easy to build.
Make it large enough and it can be used to relatively low frequency. That gets your speaker CD over a fairly wide range. You can also blend the midhorn and woofer to smooth floor bounce and high frequency room modes.
Now look at the room's corner. It expands 90 degrees from the apex. When a sound source is placed at the apex, it acts like a very large waveguide, which controls directivity down to the Schroeder frequency.
Back a woofer along with your 90 degree midhorn and tweeter into the corner, and now almost the whole audio band is CD. The only band that isn't is the modal region (under 100Hz or so), and that can be smoothed with multiple subs.
