I agree, violet is good, cyan is not.Display attached, notice the 2 notches.
Remove the diaphragm and inspect for debris in the gap, or something like a glue particle on the voice coil.
Then try rotating the diaphragm to each of the four available mounting orientations, remeasuring....
Yes. The back cap comes off, releasing the diaphragm.Remove you mean by removing the screws which hold the driver together?
Excellent!Zilch,
I have fixed it, remove diaphram (I have not done it before), blow on it to remove any dust.
Here it is. I assume the polar is vertical.Is this the link you're talking about?
Perhaps you can explain for us what's going on there with respect to aiming of the node in B3 vs. LR4:
http://www.musicanddesign.com/Power3.html
here is the Attachment....
Heh. Just look at THAT, wouldya? :thmbsp:here is the Attachment....
Well, just look at THAT, wouldya? :thmbsp:
Spot on +/- 2.5 dB; better if we ignore the VHF spike.
AKers're are gonna want to know how they sound to you once you get the woofers running with them, of course.
[And pics. We'll want PICS, too...! :yes: ]
Wondering if that is a screenshot from Soundeasy?
If not, please tell us what you use and how you like it.
Are you using the same HP and EQ shelf and boost for both drivers in the DCX?
Soundeasy is very powerful but not cheap, I got my genuine copy from my friend. The support from seller is not very good, adequate support from the Soundeasy forum.
cheers.
While both my drivers sound good, until I can measure them all this talk of tweeking diaphragms is making me wonder how mine measure.
Russellc
Don't worry about it if they both sound the same and good. Mine are audibly different. Haven't had time here to do tweaking or even decide what my next step is.
Good luck with the move.
Glad I did not get the call to assist.
LOL.
New refurbs for $200 apparently:DCX is about $250 from Ebay and easy to resell.
Excellent!
It's not usually that easy, and I was looking for gap cleaning instructions on the PE website to post. While they show a picture of the process in the catalog (P. 233) I am not finding a link there.
http://www.partsexpress.com/catalog/pdf/233pec08.pdf
The forum will now witness your prowess as practitioner of parametric equalization.... :thmbsp:
