OK, someone step up with pair number 50. Still rolling along and still picking up new e'wavers. A very impressive project, still looking forward to more work with the B&C DE 250 compresson drivers. While the 220 ti is seemingly taylor made for this project, and performance has shocked many, the DE 250 is quite a bit more clear. Once I've been listening to it and go back, I find a little residual fuzziness that isnt present on the DE 250 driver.
Also, in the begining the DE 250 seemed to to go right through my head, something very sharp. I had to turn down the attenuation WAY down to avoid this. Some say that there is a peak that needs to be tamed. I have tried the suggested cap and coil on the high pass and it seemed to help this a little. What has helped more is just play time. It now seems fine about in the middle of the attenuators range and sounds great. Right now I'm using the standard < 95 db HP, and the low pass from JBL 4430. Maybe the 2235H has a similar hump to the LE14A driver, as the components in the JBL crossover's LP seems to be somewhere in the neighborhood of around 900 hz (electrically) as well, it uses the same cap 12 uf as the standard E'wave LP, but a much larger 2.6 coil. Of course this is strickly subjective opinion of yours truely, havent yet attained measurement ability yet.
Anyone else having fun with DE 250?
Russellc
