I just measure from the front unless I'm getting real precise. Important thing is to be on axis as "reference." The actual system axis may be elsewhere.... :yes:Where do I aim it??? 1 meter from the edge or all the way in the "horn"???
Yea it ROCKS with both drivers!!!
The L pad is set at about 1:00...
CV says these are 97 DB, the woofer keeps up good with it:yes:
I see these old cast aluminum frame CV woofers all day long on E Bay cheap...
If one wanted they could always spray paint it black if they don't like the look...
I hate to give away my source, but Y'all have been good to me here:yes::thmbsp:
Only thing is I've never seen T/S specs on em anywhere, they would have to be tested if going with a different box...
Hi, I'm new to this forum and it is my first post.
I saw the Econowave during a Google search for a good replacement Tweeter (fried egg) for my Large Advents (Circa 1975 utility cabunets).
So I am now waiting for the Parts Express package to come so I can build my Xovers and install the speakers!
Unfortunately the Pyle waveguides are on B/O til 10/30/09 :tears: At least it is not too long to wait.
My Advents never sounded great to me, Bass was good but highs were dull to my ears and absolutely no imaging in my room.
Thanks to all of you for your recommendations:thmbsp:
I hope I'll be Happy (No turning back as I cut my openings for the Waveguides)!
I will probably make some adapters so I can play with these until the QSC's show up. Need to place another order with PE for the D220ti's and crossover parts so I can finish my other planned projects.Order a pair of throat adapters, #264-323....Now I have screw on horns and bolt on compression drivers.I will probably make some adapters so I can play with these until the QSC's show up. Need to place another order with PE for the D220ti's and crossover parts so I can finish my other planned projects.
