8" Square PT-D95HF-1 in AR4x
See pic @ #8897 above, right.
Vertical Polar Map:
Using the vertical polar protocol developed for QSC system measurements, we locate the forward axis via mapping the response in 3" height increments above and below the waveguide axis at a 44" mic distance from the baffle face:
Limited about the forward axis:
-3" to +9" relative to the waveguide axis, the forward axis is at arctan 8/44 = +10.3° from there.
Lower Null:
Well developed at full depth -40 dB, orange, the lower null is at WG -15" or arctan -15/44 = -18.8°. C/C distance is ~8.19".
Upper Null:
At WG +43.5", yellow, arctan 43.5/44 = +44.7°, the total forward lobe then being 44.7° + 18.8° = 63.5° tall when referenced to the waveguide axis.
Crossover:
eWave <95 dB standard highpass, lowpass = 2.5 mH/15 uF for this woofer; minimum phase on forward axis, black, inverse polarity null there, grey:
Four Drivers:
Two D2500Ti-Nd and two D220Ti:
Stunning max continuous 117 dB/1m SPL exceeds THX spec for HT mains:
http://www.jblpro.com/catalog/support/getfile.aspx?doctype=3&docid=1080
