Bauhausler
Rational Subjectivist
PR in the rear is probably the best compromise. You can then match the original cabinet size (to a reasonably close degree) and be pretty assured that the woofer will work pretty much the same as the original cabinet...
Regards,
Gordon.
Thx. I was hoping for a solution where I didn't have to cut another big hole but I can go that route. I have some nicely refinished OLA cabs that are the right size & the new baffles are already cut.
I assume there is an optimal positioning of the PR on the back surface. I have some room to play with. What should I avoid as far as positions?
