OK Chris. I think you meant the cap in line with the +.
The 3 drivers are close enough for Selenium. I have had much wider variance than that.
If you don’t want to mess with rotating diaphragms, use the purple as your Center, blue and green as your L & R.
The notches at 9/12.7/15.3 kHz all appear on my graph when I remove smoothing, and at about the same depth.
You appear to drop about 13 dB between 2-9kHz.
Mine about 9 dB.
Overall, my driver drops about 13 dB from 2K up (smoothing turned off.)
Yours drop about 15 db, if you don’t count the top end of the response, which is the most problematic for non-calibrated ECM-type mics. So I am discounting that. However, the general trend is there.
Now what you need to figure out is how you fried the compensation cap when soldering your x-o boards. All 3….
Seriously, there’s no way you did that. But look the crossovers over, again. If all is really well, then you might want to to follow Kegger’s suggestion.
I am sure other EWavers will have comments. Feel free to mail me a x-o if you want to compare that way.
Here you go...
1m away, center of waveguide, resistor inline with + terminal, no xo, 500hz-20khz sweep.
