I ran out of room on my build for the QSC waveguides but lukckily, it appears that Wayne Parham's H290C waveguides from Pi Speakers will be a smaller and possibly better replacement. No idea if they ship to Sweden. skywaverider took the Pi waveguide with my "Deluxe" crossover and the B&C driver:
http://www.audiokarma.org/forums/showpost.php?p=6113189&postcount=14769
Her's a link to the wavegudies:
http://www.pispeakers.com/catalog/product_info.php/products_id/276
An exponential horn like that ME45 defeats the purpose of the project, btw.
I have purchased a pair of Altec Santana 2 with ewave in mind. Does anyone have any feedback on the woofer or should I be upgrading that as part of the ewave?
I love the looks of the Sanatana cabinet and it is about 4.5 cubic feet. It should be large enough for most woofers, especially if I port it.
In a dream world, what would be the best woofer for that project?
I used the D220Ti wit the high efficiency crossover design. I am not certain if the woofers are >95 db but the match between the woofer and horn is very good.
I have an offer on a pair of 4311 for my next project.
I'd guess a more complicated crossover on the 125A woofer could be an improvement, but then Don's 2.5mH/15uF does appear to sum well, so maybe it's best to leave well enough alone. The woofer is not that efficient, but as long as flat response is in the L-pad range it doesn't really matter that the HE crossover is used. IIRC, he said he was measuring halfway between waveguide and woofer centers, and since he appears to have perfect summing at crossover point, that halfway point should be your listening axis (through tilt if not through tall stands). High stands with the vents heavily stuffed and some subs would probably be ideal.
The higher crossover point should be a good thing for a 10" woofer, at least as far directivity.
I could not resist... I am going for it.
Found some things I can use locally. A 1.9 cf unfinished enclosures from JBL 4428 studio monitors. Depending on the horn I would put it outside or in the enclosure. I will need to make a new front baffle to fit the horn properly.
I also purchased some old speakers that contained a JBL 2204H 12 inch woofer and a JBL 2344A horn without the compression driver.
Is the 2344A horn any good?
There is a local guy selling a B&C ME15 90x60 exponential horn with DE400Tn drivers. How does the DE400TN compare to the DE250?
I could fit the small JBL clone from parts express easily within the enclusore. The QSC would need to go outside. From what I have read, the QSC is superior.
Any suggestions are appreciated.
Alfredo
Well Folks,
Here is my first set of completed(mostly) E-waves.
They are Barzilay cabinets with a CTS woofer from some old cornwalls - reconed by GordonW. I call them magic woofers by GordonW.
It has the standard high efficency crossover, jbl horns, and the selenium d220ti compession drivers.
I still need to finish up the grills, which will have the cloth from Crites to match the klipsch fabric, and the stands which are period correct solid walnut to mach the speaekrs.
I think they look great nad sound great too.
I just wish Zilch was still here so I could thank him again for this.
Till later,
mark
