donprice
Wound up workin' at a gas station....
But a 2.8 cu. ft One 4" port ~ 12.20" tuning to 30Hz would work to? A little more spl in the lower, box size ain't a problem.
Was thinking about putting the ports on the side of the box due to the length of the port, problems?
Look at the link below for modelling results. Like DT said, tune to 45...not 30. Look at excursion below Fs (37 Hz in this case).
http://www.parts-express.com/pedocs/more-info/290-590-eminence-kappalite-3012lf-more-info.pdf
Got a subwoofer or 3? The 3012LF would not mind if you rolled it off at 60Hz. You will need a lot of subwoofer to keep up with what it can do >60Hz. (80Hz XO is THX spec but why not go 60 if your mains can?).
Put an elbow in the port? Two or three ports? Slot port? All might be better than side or rear port. Go sealed if you have a sub?
but the next project will be subwoofers so i have to find something that can match the 3012LF
