Back when DWs were $1,000 batches sold out in a day or two at most. The number of willing buyers thins out considerably with Zu's new strategy of moving upmarket.Into day four of the DW-6 sale and it's still open
This clown has "stolen" my avatar. Who is he? NOT cool.Just had a listen to the ZU Dirty Weekends and they are honestly the worst speakers I have ever heard in my room!
I think using my avatar without permission DOES make you a troll! My photo, my gear; you are an arse.You have demonstrated your dire lack of knowledge in the LSR's thread, and I have no reason to engage with you further. With regards to my 2 posts, as a new member I have to start somewhere, it does not make me a troll.
The Zu's just happened to be my latest acquisition and coincided with my membership to the forum.
It appears HiFiJames took exception to something HiFiJeff said on the LSR thread.
He copied tuberadios69's avatar, HiFiJeff's name format, and decided to crap on this thread. Not particularly original.
What were you using with the DWs before?Yesterday I drug out my 813 monoblocks and put them in the system for the first time.
Holy smokes, the speakers have come alive with those amps.
40 watts per channel of single ended power makes these sound much larger than they are with dynamics that are amazing.
I been around 4, 6, 8, 14, 18, 22, 32, 40, 50 watts hifi tube amp. I ran the DW and other similar high sensitivity input speaker on 8 watts 300b. No matter how high the input sensitivity is, the speakers will not show its optimum performance on low watt amps. The speakers are not reaching the linear travel sweet spot that gives you the crunch satisfaction. Otherwise the result is "underpowered or loose bass." If you wanna get the fullest of that 10 inch DW, you need to drive it atleast 35 and up watts tube power. (just like your amp)
That's why a lot of people are in a quest for the holy grail speaker. Sometimes its the amp too.
Very easy to acquire more power in solid state and can make those speakers sing.
I always say, trust your ears.We usually run a Luxman L550ax
It sounds great but does not immediately command one’s attention as the 813 amps which is interesting as the Luxman is Class A biased also.
Both amps are operated well below clipping.
Just curious, since we are discussing tube amps with DWs, what tap do you use since the DW are 12 ohm and most tube amps have 8 and 16 ohm taps. Ive been using mine with the loading resistor that brings the speaker down to an 8 ohm load. Im open to hearing what options other DW owners choose.
