It's not flow it's compatibility with complex oiling on a highly stressed engine. It's a high strung 122 inches making 268 HP at the crankshaft. Variable valve timing controlled by oil pressure. Near 300 pound feet of torque. Horizontal orientation.I agree that generally using the OEM is increasingly the best option modern cars. The engine management systems are getting more and more complex and precise, and there can be subtle differences between aftermarket filters that "fit" a car versus the OEM filter speced for the car that the engine was designed around. Especially for the (rare) cases where there is an upside down filter with no antidrain built in (the filter needs to prevent draining). It seems like a really stupid design to have the filter upside down working against gravity, but several cars have it.
I didn't know some Subaru engines had this vulnerability. I knew some cars have upside down, but built anti-drain into the oil system itself rather than relying on the oil filter to do it. I did some AI on that Subaru engine and it doesn't sound like there is an oil filter for it that has an internal standpipe (which is safer than a valve for leakdown when the car is parked for long periods of time). AI did point to this contraption to add anti-drain to the system -- I don't know anything about it but at a glance it doesn't seem like a bad idea (A Must-Have Oil Upgrade for Subaru FA & FB Engine Longevity).
It's not a poor design simply intolerant of abuse and neglect. Start it up and stomp it cold. Top gear (even 5th is no good) passing w/o downshifting just flat foot it. Not idling for a minute or two before shutting it down. Sensitivity to poor fuel. Messing with the tune not knowing. Stretching oil change mileage w/o verifying oil.
Mine has 165K miles on it. Bone stock other than common wear items. I've run it hard cold a few times and seen redline on occasion but generally drive it like I have sense. It doesn't consistently consume oil, only real hot weather towards the end of an OCI. Just got back from driving 6-700 miles for vacation. Got a measured 29.9 MPG and purred like a kitten 80MPH on cruise. Honestly it's a fun ride that can take your breath away on the right road.
P.S. OEM air filters too. Not cheap but they are better. More surface area plus better filtration.
I have a Cobb Accessport sitting next to my desk. Can't decide if I want to install it or not.
