I just thought of the AES/EBU standard used in digital devices, it's a 110 Ohm balanced type connection:
AES3 uses 110 ohm shielded twisted pair (STP) cable with XLR connectors up to a distance of 100 meters. AES3id uses 75 ohm coaxial cable and BNC connectors for up to 1,000 meters. "Unbalanced" coax is better for long distances than "balanced" twisted pairs.
2018-04-05 By WikiAdmin Leave a Comment
The digital audio standard frequently called AES/EBU, officially known as AES3, is used for carrying digital audio signals between various devices. It was developed by the Audio Engineering Society (AES) and the European Broadcasting Union (EBU) and first published in 1985, later revised in 1992 and 2003. Both AES and EBU versions of the standard exist. Several different physical connectors are also defined as part of the overall group of standards. A related system, S/PDIF, was developed essentially as a consumer version of AES/EBU, using connectors more commonly found in the consumer market.
AES3 and AES3id - Short and Long Distances
Aes Ebu
Hardware connections
The AES3 standard parallels part 4 of the international standard IEC 60958. Of the physical interconnection types defined by IEC 60958, three are in common use:- IEC 60958 Type I Balanced – 3-conductor, 110-ohm twisted pair cabling with an XLR connector, used in professional installations (AES3 standard)
- IEC 60958 Type II Unbalanced – 2-conductor, 75-ohm coaxial cable with an RCA connector, used in consumer audio
- IEC 60958 Type II Optical – optical fiber, usually plastic but occasionally glass, with an F05 connector, also used in consumer audio
