2 ohm rated solid state amps
Pretty much any McIntosh amplifier with Autoformers will drive 2Ω loads all day long.....
with a speaker that efficient, you may not have have much to worry about since you're never going to use more than a few watts. it would help to see the impedance vs. frequency curve of the finished product -- do you have that?
Assuming this is for me, no I don't. I inherited the cabinets and am still saving up for the drivers/horns, amp(s), DAC/Preamp. It's definitely a 1-3 year project.
You can check these threads to see if they answer your question though.
The speaker will basically be this 2-way Cornscala http://www.critesspeakers.com/cornscala-style-d.html, but with this Cornwall double bass bin http://forums.klipsch.com/forums/t/135226.aspx?PageIndex=1.
Each bass bin is isolated and independent, presenting 6 ohms - but when wired in parallel drops the overall impedance to 3 ohms. The top end will be the 16 ohm version of the Faital, so no worries there. If I can't figure out a decent solution, I'm thinking about only using one woofer in each cabinet and basically having an oversized Cornscala in my room. It's a small-ish space with the listening distance about 7ft from the speakers - so it's not like hitting 85db is going to be all that difficult.
I agree that with their rated efficiencies I should be able to use just about anything (the Yamaha A-S2000 certainly has my eye), but I'm worried about spending that kind of cash on an amp and burning it up by being foolish.
A guy on the Klipsch forum drives a similar version of my bass bins with a McIntosh MC-250 and says it's great, if not slightly lacking in power. A McIntosh MC-2100 should also fit the bill, both of which are are around the same 1000-2000 after you factor in the initial purchase plus an overhaul.
Too many choices.
GAS Son Of Ampzilla will handle a 2 ohm load.
JimFet, I used to work for Koss in the 70's. Much of the listening we did on them was with a GAS Ampzilla and Thaedra preamp. In a huge board room.
I drive the ribbons (2 ohms)in my Magnapan MGIIIa's with a Acurus A200 and it never gets more than warm at high volumes. FWIW
Regards,
Jim
Threshold s/300's have no problem driving the DVC Watkins woofers in my vintage Infinties and pretty sure I've read they dip down to 2 ohms (perhaps less). Same can be said for my Aragon 8008 and Soundcraftsmen MA5002.
I have a buddy that has Kappa 9's that he is looking for an amp for. The speakers have all been rebuilt/refurbished by local vintage expert. He has a huge inventory of Carver and Sunfire but for a reasonable price he recommended my buddy watch ebay for a McIntosh MC-2300. He said it will handle loads to a fraction of an ohm
Most high quality solid state amps will do 4 ohm loads no problem. :yes:
Does anybody know any manufactuers of vintage amps that will do 2 ohm loads? :scratch2:
Soundcraftsmen comes to my mind.
Hafler. Particularly the XL-280 and DH-500.
Thanks for all the info
Thanks for all the great information!:yes:
The Haffler's seem to be the most reasonably priced. Mac are nice, but very expensive. :tears:
I put the hurt on my SAE running it to hard at too low of an ohm load. :tears: So I need to either split the load between two amps or one that will handle the lower loads. :yes:
Looks like its time to UPGRADE!:banana: That's why I go to work, to buy more expensive audio gear!:thmbsp:
Anybody mentionned NAD.
My 2200PE would handle some 2 ohms but, I would not try it, for it's sake !
Both the 208 and 2700 that I use on my Kappa 9's are 2 ohm stable and have been handling the load for close to two years without issue. :music:
My Tandberg 3016A will do 2 ohms all day, if the house AC supply can stand up to it. Has a 1 ohm rating too but I've never put that to the test.
John
i cannot believe that nobody mentioned the ADCOMs. back in the day, ahc needed an amp to drive the apogee scintilla, a ONE ohm ribbon speaker. an adcom 555 did the job.
also as i understand it, dan d'agostino designed the krell for just that purpose.
