All this numbers are nice, great for shop talk, and "trusting" ? a amp to drive 2 ohm loads all day long can be comforting to some.
The big test is really how it performs with these loads. Doesn't surprise me H/K doesn't respond, the designers of those amps have long left the company. Unless you have actually tested the amp with said speakers and musical program material, all your mathmatical figures are mere assumptions on how the amplifier may perform, little else.
Again, how it sounds-most pro amps put out lots of power, but most to my ears aren't very musical regardless of their specs so to me what's the point?
Usually there is a reason most choose a audiophile amp over a proamp for home listening-it's the sound, not marketing. And most proamps are considerably cheaper spec wise than there audio conterparts.
I have both a PA2400 (direct coupled design) and a H/K Signature 1.5 (built my Mark Levinson- the USA). The 1.5 will double it's power (200wpc) into 4 ohms (400wpc), according to the designer (will foward thread when I find it) of the Signature 1.5 (no current limiting switch or design), and will drive 2 ohm loads all day long as well at around 750 wpc, according to the designer, but H/K the manufactor doesn't recommend it
So we have to conflicting specs and perspectives on one amp, the H/k 1.5 from the desinger, and the manufactor.
I have also driven a pair of Infinites with the PA2400 in the 8 ohm setting for hours with no problems, or excessive heating. Both amps recently tuned to specs. It uses 8 15amp outputs and 48000 total filter caps
To me, this means that the specs are only a starting point, and nothing more till you actually try the amp in real world conditions.
Both these amps have very stout power supplys, very large torodial trannys, and 15 amp outout transistors. The 1.5 uses a toal of (24) 15 amp output transistors, 65,000 total filter caps, so the ratings the designer specs of this amp aren't out of line. But again, it's all talk till you hook up the wires and press the power button, how it sounds driving the speakers is what matters.
In my experience, and given a wide range of rating on amps (conservative-not), instead of saying this amp should put out 5400 watts @100amps current vs 350 watts etc, borrow one and see how it works.
I don't take any offense to the H/k comments, interesting-but performance, not specs are what matters.
