rabbit
Well-Known Member
Gotta be way lower than 2 ohms. Twice I've asked H/K for the test criteria used to determine the HCC number, but no reply in either case.
The only thing that makes sense is something very low, like 0.1 ohm; maybe even lower.
If we go back to the forumulas, 5,000W at 2 ohms doesn't match up with the 100A HCC spec nor the plausible output voltage for this amp.
Read the paper by Otala and Huttunen entitled Peak Current Requirements of Commercial Loudspeaker Systems JAES, June 1987 or read the section in Doulas Self's book on "Enhanced loudspeaker currents".
The amp will not deliver +/- 100 amps peak into an 8 ohm load. This is not what the HCC specs are eluding to.
You don't have to use a 0.1 ohm resistor to sink or source high currents from an amplifier. The combination of certain waveforms along with certain reactive loads along can indeed draw many times the current with respect to the nominal rated impedance of the load.
Like someone else said the H/K amps are pretty generous when it comes to the quality and the number of output devices used
