If you are that interested in it why don't you get the Otala paper and read it instead of speculating about it because you are just going around in circles. The paper will most likely discuss the conditions of which the tests are made including the simulated loudspeaker load.
I don't have any problems about the H/K claims whether they are real or imaginary. The simple fact of the matter is that I have used the HK PA2400 with my RS4.5's since I got them and I have had no problems with premature clipping or over current protection muting or any other intrusive limiting. You can tell by their circuit topology that they are no lightweight contender.
These amps can be picked up for a bargain price because people don't know about their capabilities of driving difficult to drive loads. They are a much better proposition than many larger and much more expensive amps and receivers designed to deliver lots of power into 8 ohm loads only and which can literally destroy expensive emit tweeters even at low volumes
I agree Rabbit-your experience with the PA2400 driving Infinities tells way more than speculation or a need to find out H/K "ain't tellin" specs-in reality they are irrealivant-the proof is, as they say in the pudding, and your experience speaks volumes.
I agree the PA2400 is a wonderful amp, one of the top five amps I have heard, period. And I have had it driving several models of Magnapans, Klipsch, DLK, B&W and Canton, and have come to the same conclusion.
The H/K Signature 1.5 (built by Levinson) improves on it, very slightly though.
A improvement in clarity, slightly more transparent, but otherwise the two amps are very similiar. The 1.5 is better spec wise on paper, particuliarly it's rating into 4 ohms, as it doubles it's rated 8 ohm power. into 4 ohm loads.
And I have yet to compare it driving 1.6 maggies, but I imagine the difference to be slight. To me this clealry validifies the specs have little to do with the actual listening experience-and are some what meaningless without having the equipment in front of you.
Unless you have actual experience with these amps driving similair low ohm, or complex loads, speculating on how H/K, or any other manufactor rates their amps isn't particuliarly useful to the original thread- *amps capable of driving Infinites* (which aren't 2 ohm, if at all at any frequency, but are probably in the 3 ohm range, as well as inefficient-a double whammy), and comes off kind like bashing for no useful reason.
Perhaps interest in H/K's rating practices is better suited to a original thread.
