Is the voltage at J722 normal now, approx. +15VDC? What are the voltages on the EBC of Q746?
Craig
It may be a long shot but it couldn't hurt to pull the trim pot and make sure its tracking accurately. Other than that, with the new zener in, please confirm EBC on both Q746 and Q747 for us. Q747 should be E:15.3v, B:15.9v C:35.6v
Q750 I believe is the regulator for the tuner supply but it couldn't hurt to test this as well since its collector is tied to the others.
Sorry Craig, but that made my brain bleed a bit. Can you explain what you mean by "....should NOT be connected..." and "....NO dot directly below..."?Another Marantz schematic error, Q748/C723 should NOT be connected to the base of Q747. There should be NO dot directly below the base of Q747.
Craig
