Dearslayer
Good point. So should I just leave the old transistors in place would you recommend??
...I could be wrong here but I believe I may have the wrong transistors for the 1815’s. The package has Part # 512-KSC1815YTA but the marking on the transistors themselves don’t match with the Datasheet on the Mouser site for the 1815’s. The actual marking on the Transistor is as follows…….BC547 B-F38 . From what I see it doesn’t match with the data sheet for the actual 1815...
QFT for sure! I knew a VERY smart engineering tech and when he was complimented on something he would say, "I'm not smart, I just remember more stuff than I forget!"We learn more from the things that go wrong than we do from the things that go right.![]()
Don't bother trying to unsolder all of the red and white wires soldered to the cap lugs. They are difficult to remove. Just make note of what goes where and clip them off at the lugs. Strip off 3/8" of insulation and solder to the new caps. This will save a lot of time and tedious unsoldering.Got the new 1815 transistors in today from Mouser and just finished installing all the new ones plus the new 992's that I had removed on the 400 board ( so all new ) and everything seems to be working just fine now. So glad I can put that headache behind me and move on toward the finish line. Filter caps here I come. Any advise on these?
