I may have to drag the Kefs to your house before you move that.
Are you planning on venting the case? It looks awesome by the way!
McMaster Carr has all the perforated metal you could dream up, doesn't come all that cheap though. Worth a look since the original case vents would be impossible to get.
Beautiful work on the restoration, I'm amazed at how well you made it come together.
You are more than welcome to. I was able to flex the 2500 today for my brother with my rebuilt 103.2's and I am just in awe. These speakers are somewhat magical to me. And aside from their ability to make each instrument seem to come from its own woofer, the linear excursion is phenomenal. I would love to hear how the 104's compare.
Thanks. Yes it will have the 6 openings at the top and I'm thinking about buying a Marantz cover from ebay to cut and recess into the sides. Finding the original vents for a good price would be hard, if I could find them at all.
Other than that its been running flawlessly. This is a stunning unit to look at and listen to. I'm jealous that you have the 2500 and now the 2600!
This is the front side of the panel, it looks countersunk. But the insert looks like it's crinkle painted or maybe even plastic. I bet it't not original..
Maybe someone with a real WC-124 can chime in....
Thank you for the clarification. The picture from ebay was deceiving until I saw the other panel. It looks like the case on the brochure doesn't have mounting hole inserts either, they may have came later.The insert is made of plastic with the side exposed to the outside has a textured finish on it . The inside finish on the plastic insert is smooth . The side panels from eBay are correct . The holes are countersunk on the other side of the panel . The eBay picture shows the inside side of the panel that fits up against the receiver . My wc-124 case doesn't have the inserts for the two countersunk holes on the side panels but have the plastic grille inserts . Hope this helps ,
Shroomdog
Knobs are lost in this guys shop somewhere. I am planning to go there and hunt for them. He's certain they are there. Say a prayer for me...Where are all the knobs for it?
