6V6 SE build problem...
knockbill
Lunatic Member
I tacked together a 6V6SE amp, with a 12AX7 driver, and 5Y3 rectifier... Had it working pretty good, just needed to mount the OPT on the chassis, which I did this afternoon... Now, as B+ is powered up (variac) to around 230VDC, it drops suddenly to zero reading at the 1st cap (10/450v) after the rectifier,,, However, the 2nd and 3rd nodes still read respective voltages... I tried replacing the cap, the OPT, and even tried it with a separate PS, it still shuts down, possibly shorting out somewhere, can't find any stray wires, tho ... I noticed I could take it to full voltage(350-360) with the VC shut completely off, but just cracking it on will shut it down again... So, I changed the volume pot, thinking it may be shorted... also, swapped OPT primaries in case they were backwards, no joy... By disconnecting a speaker clip lead momentarily, it has a hi pitched oscillation, I'm asusming from teh output tx?
I had this thing running with a CDP for hours before today...
Figured I's give it a rest, and vent here!!
Any ideas are welcome... its too simple a circuit not to work !
Kind of off topic Bill, but when you get her all lined out, and get some free time (yeah right), make yourself a pair of adapters to run 6AQ5s in the 6V6 holes, the find some JAN 6005s and see what you think.
On topic, no chance the feedback is hooked up backwards is there?
Edit, that circuit is just begging for the 2.50 cent screen regulator too FWIW. IMHO of course.
Sounds like the screen on the 6V6 is shorted. Pull that out and see if the voltages make sense. If not, pull the 12ax7. Has to be a short to ground to show 0v at the second cap, unless the 10k resistor is open.
Tried it with and without FB on both leads, that couldn't kill the B+ would it?... This one seems strange,,, I was going to build it with 6AQ5 originally,,, used an old Webcor chassis, 2 12AB5s, and a 5Y3, seemed to be made to order, even had 2 proper sockets!!! But, the tubes hang upside down, so I used a 6V6 and a spring retainer...
I tried 3 output tubes, and a ouple drivers so far!!! Pulling either 6V6 or 12AX7 will clear the problem, I got the PT out of it now, and tried it with the big Maggy PS, it even shut that down...
Now you got me thinking,,, I replaced the 1st cap, no joy... Maybe the screen cap is shorted, it only clears with one of the tubes out, or the VC off... If the CDP is running as it powers up, its very distorted, may be the low voltage, tho...
This was supposed to be a quick project!!!!
PS... it shows zero on 1st cap,, 2nd and 3rd stay relative to variac setting...
Might be that the oscillation is causing it to draw heavy current and tank the voltages. Thats about the only reason that messing with the volume control would affect anything on the power supply.
I figured it had to play into it some how,,, whats the fix? Only change is bolting the OPT in the chassis,,, unless I did something else, and forgot already!!
I can retest the tubes, but they were good... if they're shorted now, this amp did it... gotta sort it out before it eats any more...
Try grounding the grid of the 6V6. if the voltage comes back to normal, its an oscillation problem. If that does it, maybe a small value cap to ground across the volume pot will get it done. If you have anything in the pf range, try that.
Here's something to try: remove the output tube and in its place put dummy load resistors (of proper wattage dissipation) between plate connection and ground and between the screen grid connection and ground--thus simulating the quiescent current draw of the output tube. If it still misbehaves, it's gotta be in the power supply or in the OPT somewhere. If it powers up fine, it's gotta be the output tube.
Its wired correctly, I restuffed a can for this build, and it had been working,,, just to be sure, I cut the 1st stage out and tacked a new one in...
Thanks for the thoughts!!
Output transformer shorted. I have an old one from a Philco radio with only 3 leads on it. has internal ground.
OK,, got back to it a little... did some reading on guitar amp forums, seems this is a very early and much modified design,,, lots of talk about oscillation and grid stoppers... I remember having a problem with slight oscillation as I brought this amp up the 1st time,,, as there are no PS voltages on the schematic, I read that the higher the voltage the better they would sound, til the tube gave in! saw anything from 320V to 420Vp,,, I was at 360V or so, to start with, and found that 330V was near the sweet spot, when it was running and not oscillating...
Also, I tried a 22K grid resistor on the driver, which didn't help, til I brought the Voltage down (its removed now)
I retested all 6V6s I was swapping in, and they read the same now as before...
Today, I put the PS back the way it was, and tried it, same shut down results, So on to the tests...
Shorted 6V6 Grid to grd which didn't help...
Pulled the 6V6 and put 60k load on the plate, 30k on the screen (manual said 50-80k for plate, didn't list screen R)... brought it up to 426VDC, and it held steady til I shut it down... this seems to indicate the tube, but they can't all have the same symptoms,correct?
I'm just glad I didn't fry the PT at this point!
Since it worked correctly before you mounted down the OPT, then consider that either the location of the OPT when mounted or its lead dress has caused the problem. To prove it, remove the OPT, and tacked wire it the way it was before when it was working correctly. It does sound oscillation related.
Dave
I can do that, however, I tried 3 different known good OPTs with the same results, even tho they weren't bolted in the chassis they were physically fastened to it close to where it fits, leads are on opposite side from signal... I'm thinking more oscillation, also... I may need to do more research to understand how the git guys overcame this problem...
Thanks for the reply....
try about a 1k grid stopper resistor, with the resistor as close to the tube socket as you can get it. Might need this on multiple stages.
I moved the OPT out of chassis to where it was when it worked,,, I think the fact that it worked was the fluke, as this design as is doesn't seem to work properly from what I'm reading... Just tried 5 more OPTs with slightly different primaries, and it did the same thing,,, shut down at similar voltages...
Think I'm going to look for a revised design for this schem to see how the oscillation problems were handled... without having the exact OPT and PT used originally, I have to figured mods are going to be necessary to use tx I have....
Have you tried running it without feedback?I couldn't read the original well, this is the same,correct?
That's what I'm finding also... can put them on 6V6 and both triode grids,,, think 1K is right for teh driver also?
This is supposed to be the simplest Fender git amp build there is,,, many guys selling kits, but I'm not finding the revised schems... seems to be the same problem I had with the original Challenger/Bogen PA amp last fall, finally ended up using a different Bogen schem,,, you saw the results!
Original OPT has to be mandatory for this plan to work as is, I guess...
I'll get it, just didn't want to spend this much time on it!!!!
Thanks for the help...
