6V6 SE build problem...
Found this bit of info on a "forbidden" site...didn't post teh thread in case it was corrupted... Would a resistor on teh screen help with my problem? I've seen it mentioned before....
"A little secret.....
B+ to the choke, use a fender deluxe type. Then the plate of your power tube, a 1K resistor, screen then a 22K resistor for the preamp. You can go as high as a 27K or as low as a 10K.
In a push pull amp the plate goes at the same node as the choke. This setup works better for an SE amp.
The 1K resistor can be changed to anything up to 10K even and you will notice an effect people swear you cannot get in an SE amp, SAG. I also use a 470-1K screen resistor directly to the tube socket and at least a 1.5K grid stopper.
Run your heaters like the later model fender with twisted pairs and 2 100 ohm resistors to ground either at the green AC ground wire at the transformer or to lift it to a higher level at the actual cathode of the power tube before the resistor and cap get grounded.
I use 4 20mfd caps for my power supply. You could try different values but I would not go over 30 for a 5Y3 and 47 for a 5AR4/GZ34. Everything you do to your B+ will effect the sound/tone of a champ drastically. Also you can mess with the preamp plate resistors a bit too for more gain as well as the cathode resistors.
Use chop sticks with the amp on and volume all the way up and move things around a bit to find any bad solder joints or improper wiring as in lead dress."
Here is part 2 of a build of this amp that has only a little variation from the original that you might find useful. The other parts should be linked from that page or by going to Uncle Doug's youtube channel.
Thanks for the links... I just added a 1k grid stopper at each triode, and it seems stable,, not much volume tho...feeding it with a tape deck, so it should be pushing a lot more then the guitar PUs... Didn't put a 1k on the 6V6 grids as it already has 220k to ground, figured 1k more is within its tolerance...
After the volume/gain problem is sorted out, think I'll tear it down and start over, this chassis is pretty small to start with, so I'll bend a new one, and hopefully end up with a clean build...
Thanks for the input, so far...
Is the 1k in series with the grid, or to ground? In series it shouldn't affect the gain much at all. Its working into basically no load, so you won't have any voltage drop to speak of across it. If thats 1k to ground, it will kill the signal.
Its to grd,, isn't that what a grid stopper is? figured something was wrong!
Thanks for hangin in here... been reading about this amp, seems .02 coupling caps are usually reduced to .01... also, this is one of hardest to get right, guess that's why there are so many modifications.
I'll move them to series and see what happens...
Just put them in series with the signal,,, the voltage stayed up, but the oscillation squeal was back... I can try reversing the OP primary leads, but I don't expect it to help...
I have to find a better schematic,,, this chassis is getting trashed with all the "fixes"... Like to see it work 1st tho!
The grid stopper resistors are typically in series with the signal. There is also a separate grid to ground resistor that needs to be there for it to work. Looks like they are using the volume control as one on the 12ax7 and the 1 meg on the input jacks as the other. You might try changing those to 470k on the input jack and a 500 meg pot for the volume, or just strap a 470k across it. 1M on the grid will make it prone to picking up every bit of anything.
Maybe theres a reason Frank Zappa called these a cheesy little amp.
The grid stopper resistors are typically in series with the center stage re is also a separate grid to ground resistor that needs to be there for it to work. Looks like they are using the volume control as one on the 12ax7 and the 1 meg on the input jacks as the other. You might try changing those to 470k on the input jack and a 500 meg pot for the volume, or just strap a 470k across it. 1M on the grid will make it prone to picking up every bit of anything.
But oh could Zappa make those cheesy little amps sing! I saw him and his band play several times. Front and center stage was a champ with a microphone in front of it. :music:
Yep,,, and hes not the only one...
I can't find a schem of this thing with PS voltages on it,,, the cathode voltages are right on... I think it should work with the way its drawn out, even with the OPTs I've tried,,, I can keep "tacking" parts on it, but I'm close to stumped now...
Whats next?
When I had the 1k resistors to ground, the amp seemed very stable, and also very quiet... if 1k is shorting too much signal to ground, would using a higher value work better? there has to be a correlation between the the grid to ground and the problem?
Here's a pic of a similar amp, tho with no FB... It has the VC after the 2nd stage, but has an input cap, and most notably a 6.8M resistor grid to grd on the 1st grid, as my amp has 1M connected to the switch tab of the jack,,, If the jack is wired incorrectly, could it take the resistor out of the circuit when the jack is plugged in??
Thanks for the input,,, this has got to be something stupid simple that I'm missing!!!
Possible that the jack is miswired and opening the ground path. If you only have one input jack, you could just put the grid to ground resistor right at the tube and know it won't disconnect.
That's what I was thinking,,,however, there are two jacks so one should be closed... The jacks are wired differently, for hi-low input... I'll disconnect them both, put 1M from grid to grd and wire in a 68K in series with the tip... that 1M needs to be on the grid to keep it from oscillating, correct?
This thing has got me baffled!
Needs to have something to ground in order to reference it and bleed down any leakage. Get it too high though and it won't overcome any internal leakage and it also gets too sensitive. You'll be picking up mouse farts on Mars.
That's what I mean, just put the 1M grid to ground, maybe 1M it too much, I can try a pot... I found a bunch of "fixes" for these amps oscillating on a guitar forum...some have conflicting info, so i'll to sort em out and see what works... Bet it ends up being something simple, tho
Think its possible P2P wiring is causing the oscillation? seems these were originally built on turret boards, with 20 or so long wires connecting to the switches, jacks, etc... I figured P2P would eliminate the long wires, and help with the oscillation problems I've read about with these amps, specially around the 12AX7s tight socket... another reason I'd rather use 6SL7's, if it will fit the chassis... Octals are easier to work with...
I'm thinking with two pre amp stages, these instrument amps are similar to a phono amps' high gain, and suffer the same build problems...
Didn't expect this to be a whole winter project!!!
Possible its lead dress related. It may be that this one is especially cranky about precisely where things are located, though turret board construction with long wires I would expect is more prone to oscillation problems than neat p2p wiring would be.
