I think you said a while back that the amp was not oscillating when you had the OPT out of the chassis. Was that true? If true, that does lead one to the conclusion that it is lead dress related. And do you know at what frequency it's oscillating? I assume at this point you've tried grid stoppers on both 12AX7 grids, and screen stoppers on the output tube?
Have you tried clipping in an alligator lead directly on the first tube's grid to ground, just as a test to see if that first grid is picking up stray noise?
Finally, I assume it will stop oscillating if you only connect the second 12AX7 stage (meaning remove the first stage from the circuit)?
