6V6 SE build problem...
Have you tried running it without feedback?I couldn't read the original well, this is the same,correct?
You could probably put a cap across the 22k,or 1.5 k resistors in the FB loop to stop the ocillation, I have no idea what value
Hey Scott, Yep, that's the original schem,,, I did try it with and without the FB resistor, even tried substituting the resistor with a decade box, no improvement... I think Gadget is correct, everything I see on the guitar amp forums mentions the oscillation problem, but they are modifying the amps way more than I want to, for now ...
Next move is to find a newer schem designed around this guy, and just match it, if I have an OPT that will work...
Ill be watching to see how you get this one going. Im planning on building one for my son.
Hi Paul,,,
I just put pick ups and pots in my buddys Strat,,, wanted something to try it with!!! turned into a marathon! I'll give you the best advice I found so far,,, don't use this schematic!!! there are many kits out there that include tx, I assume they work .... Hell, I even built a cabinet for this, in anticipation of tacking it together in an afternoon!
Did you try a different power transformer? To me it looks like a bad PT or OPT. Have you checked for a short from the pins to ground on the tube sockets? I had one where the solder ran to ground and created a short because the solder lug did not take the heat. Good luck.
Well, it still oscillates without the FB, I can try it tho... I read that some guys are taking the caps off the cathode resistors, for a different sound... this schem calls for 25/25V K caps,,, I used 35/50V cause I had em... maybe too much??
Increasing the cathode cap could have something to do with it,it would make the 6V6 able to draw more current during oscillation
the 47 is the cap I was thinking of.You already did what I was thinking
A bunch of them, I checked out the one on it now this morning before I put it back in... I went thru the joints a few times, but its getting closer to a do-over!
The first cap is a 16 in the original,Try a 25?
I tried a 22 in there when I 1st noticed the problem, didn't help... Its got a 5Y3, 1st should be a 10, no? I have a drop resistor (1150R) right after the rectifier, to lower the voltage to the PS divider, I could put the 22 on that, I guess... there isn't much room, tho... I was going to use a choke but no where to fit it...
Seems we are on the same page,,, there are two 35uF caps on the cathodes,,, I will drop em both down to 25 if I have them, and try again,,, that should be easier than accessing the grid stoppers, but I expect it will come to that!
Seems Fender was the last guy that built a working amp from that schematic!!
Sometimes "simple" amplifiers are not so simple. I've had more trouble out of basic AM tabletop radios than complex tuners in terms of making it behave itself. There is a special wizardry to that minimalist engineering at times. Unless you hold your tongue at just the right angle and assemble it with the right incantation on a certain phase of the moon it just won't go.
about the cathode cap. Removing it will introduce some local feedback to the stage. Normally all you get from an overly large cap in that spot is the possibility of some low frequency instability. Pulling it entirely might choke off the high frequency oscillation, but largely because it drops the gain of the stage a fair bit.
I'm gonna call Mr Muntz!!!!
Well, I know I'm not using the right tx from the schem, but theres millions of these things out there in some form since 1946!
I just reduced the 6V6 K cap to 25uF, no joy,,, I'll re do the driver cap later,,, and if it doesn't work, I'll try to get the grid stoppers in there... 1K for all three, you think to start?
These things suck ya in,,, never expected to be messing with it more than a week!
Interesting,,, the point of these amps is the hi Z, they have bass amps for the lows... I think this amp has too much gain from what I heard while it was working anyway,,, could only turn VC to 2-3 before it was too loud,and much more pushed it into distortion, but git players want that... I used a CDP in the low input, and it sounded reasonably good,,, the guitar sounded good in either input, but it only had one working PU then...
I've just got to luck into a decent updated schem... I'm not the guy that can modify this one...problem is, all the info I saw online is pretty old and they removed the schem links...
Guess I'll have to hump that Bogen up here to mess with the guitar!!!
