6V6 SE build problem...
Another update...
As I can't leave anything alone! The 5F1 has been bothering me since I built it, as it can sound good, but I needed to use a 12AT7 driver because it has too much gain, and it would not work well with any FB...
A couple of weeks ago I took it to the bench, determined to get it running as god and Leo intended!!! After a lot of testing, adjusting, etc,,, I decided to look at some other Fender Champ type schematics, and found that there are at least 3 different versions of 5Fx 6V6SE amps,,, subtle changes but they must have been made for a reason... I found that some models eliminated the K caps from different stages, and one had an added tone control...
I ended up removing the bypass caps in all three stages, and worked wonders for this build, with the OPT I used... So, its basically become a 5F2A Princeton, and the tone pot replaces the FB pot I originally used...
Think I'll leave it alone,,, for now!
Well as fate would haunt me,,, I dug this guy out and decided to find out exactly why it was giving me fits over 10 years ago!!! I Polished a teh cabinet,, cleaned pots, jacks and sockets, plugged a Strat I was working on in it,,, and got hum, and sound completely dropping out... A couple taps on teh cab and it would sputter a bit, but was very intermittent,,, so down to the shop,,,
After a tube change, and a few choice words,,, i pulled teh chassis and found with a pokin stick,, it would play and stop probing wires near teh OPT,,, I narrowed it down to teh secondary side as it was a multi-lug Stancor replacement TX,, with 4-5 different lugs,,, Easy fix, I thought,,, nope,,,, reflowed all teh exposed lugs, even the ones I wasn't using and still no joy,,, Finally cut into teh paper wrap and exposed teh bottom of teh lugs,, and they all had cold solder joints,,, reflowed em and all but one worked,,, and of course it was teh 8R tap I needed!! Seems teh wire to teh winding from teh lug broke off when I glued teh paper back on,,, but I found it and it works now,,,
I think the moral is you can't win if ya quit!!!
