6V6 SE build problem...
Update,,,
Roundover bits came yesterday, so I worked on it a little... used some kind of very porous fabric for grill cloth , guy at hardware store said it was for under rugs??, but I can see thru it... Put a 12"/ 30W University speaker in for now,,, sounds better than I expected... Tolex is out of budget for this guy,, so maybe give it a clear coat, some cigarette burns, and beer bottle stains, and beat the hell out it for a while!!!
I think they may be 8 actually, not 100% sure.
Tung oil or danish oil would probably look pretty decent on there.
How did you know??
On the 3rd coat of Minwax Antique oil, left over from the Advents!!!
If you trip over them soon, ohm them out... I can still probably use one...
I've been tripping over them intermittently for about 2 years. Its just cold out there right now.
What can I say John, true art as expected from your bench. I got me a really cool looking old amp that has Rock Ola written across the front that's going to be a guitar amp someday. I run hot and cold on those things, I wish I knew more about them, but they sure are fun to play with. You can load them up with buttons and lights and all other kinds of sparkly stuff. So does it sound as good as it looks or better. I've always been of the belief that the 6V6 was a better guitar than HiFi tube. (Jay sneaks away quietly back to his hole)
Thanks Jay,,, It sounds good with my buddys strat with 3-4 different PUPs,,, so it'll go CSN sweet and clean to Ray Davies ripped speaker distortion... never wanted to spend this much time on it but it sucked me in... Thinking of building the other front end, just to see what the pentode sounds like, compared to the twin triode... probably bend a matching chassis and just swap em in the box....it just never ends, does it!!!!
Rock Ola sounds like fun,,, PP I guess? I still want to try the git with the 70W RCA PA/movie amp... It has a couple mic inputs which may work OK... these git amps are quite different then audio amps, as I'm learning... seems smaller OPTs that saturate are part of the "sound".... gotta have the distortion!
Have fun...
guitar amps are a very different world. The stuff that is good for guitar is often the stuff you specifically avoid for hifi. Kinda makes me wish I had any interest in playing one, I've got enough crap around here to build some nice guitar amps. I wouldn't mind getting my hands on a wheelie Hammond though, and those you can do fun things with instrument amplification as well. I'd have to learn to play it though, and one of those eats a lot more floor space than a guitar does. You also need several good friends to help you move one of those things, a guitar you can just stick in a case and haul it yourself.
Yep,,, these things suck ya in... started out replacing the guitar switches and pots,,, then it had bad PUPs,,, the loose pots tore the wires out of the pickups! long story short, wanted a small amp to try it out on, and a marathon month later we got this one!! So, I still have the git and trying to remember how to play it... but it really is fun, maybe relearning it will be the new winter project... Put wheels on your Hammond, and shove it where ya want it, or tow it behind the towncar,,, hell, maybe we can start a band,,, play the bonfire at Kutztown!!
I was practicing this afternoon,,, this little amp really sounds good, glad I didn't give up on it.....
I finished another little Champ yesterday, used the 5C1 schem on it, and it came out just right, with Tom Bavis' tx archive help!!! So, with that experience, I went back in the first one to see if I could figure out why it needed so many mods to get it to work,,, and I traced it back to the OPT I used... even tho it measured OK for an SE 6V6 amp, it just didn't play well with this circuit,,, I dug out a Stancor universal OPT, which I didn't try before, as I thought it was PP only, but it turns out it is also fine for SE duty... the instruction sheet, (thanks again Tom!) said to use CT and one end of the winding for SE, but also said to use the full winding in another sentence, and that's what worked, and worked very well... guess its wasteful to use an 18W OPT on this amp, but I know where it is, if I stumble across a matching Champ tx at some point...
This change brought the voltages back where they should be , and is using a 12AX7 instead of the 12AT7 I subbed to kill the gain...
Think I'll lay off the git amps for a while, they really get addictive!!!
Pic of the pair, still need a handle for the new one...
Thanks again,,,
I was banging on the new one a few hours last night, and it really sounds good... lots of bass, hi treble,,, and it just rings.... not sure if its the smaller speaker, big OPT, smaller PT, or the single stage preamp,, but I like it!!
If you are still thinking of building one, take a look at this circuit...
. Looks like they are using the volume control as one on the 12ax7 and the 1 meg on the input jacks as the other. You might try changing those to 470k on the input jack and a 500 meg pot for the volume, or just strap a 470k across it. 1M on the grid will make it prone to picking up every bit of anything.
Been thinking about this for a while, and today I decided to try lowering the VC pot and grid bleeder to see what affect it would have on the circuit,,, If I understand it properly, lowering those two resistors will allow more of the signal to bleed to ground, and lower the gain... it worked very well, as a couple hours on the guitar confirmed... I could drive the amp to oscillation easily with the 1M pot/resistor, but now, with the FB pot turned up, it just goes into controlled distortion, as I expect it should (never heard a real vintage 5F1 Champ)... I decided to go back with the 12AT7 preamp tube, and seem to be refining this guy a little at a time!!!
Thanks again for the input...
