Gigantic
A big, big love
A number of us have gotten tremendous results from the PRV Audio D2200Ph driver and to be sure, it performs better IRL with the PRV WG45-50 horn than its stats from the manufacturer suggest that it should. It is perhaps one of the best values in High Efficiency Audio out there. That said, it's not without its flaws: on paper, it's specified to only extend down to 500Hz; a number of us are getting it down to 400Hz with the WG45-50, but in making it extend that low, we do run a risk of distortion. I've not encountered it, but the risk is there, just the same. The other problem I've encountered is that in crossing over at traditional points of say 5000 or 6000 Hz, we either have significant overlap with the tweeters if using low order low pass filters, as the D2200Ph extends upwards to 8kHz, before its mass rolloff or we have excessive phase is we use higher order filters. I've found this to be especially problematic when implementing a quasi-linear phase filter scheme with a DSP and parametric EQ.
I have been digging around and found another offering from PRV, the D4500PH. Grated, its nearly triple the price of the D2200PH, but given the paucity of 2" drivers that extend below 600Hz, it's still considerably less than other options. Whereas the D2200PH has quite a few peaks in its response, the D4500PH is comparatively flat from 500Hz, all the way up to its peak 7K.
if it performs like the D2200PH does down low in the WG45-50, it ought to be more manageable at the top of its range with IIR PEQ and/or low order filters, no? What says youse? Thoughts?
