Yep, and this is why when naysayers interrupt my progressive posting of one of my current experiments, ignoring/understanding the stated, incremental/unfinished/unequalized real room measurements 10 ft. away that go against their beliefs that all measurements should be made on axis, at 1 meter, or in a plane wave tube from unstated horn data from Manufacturers.The only way to tell is to buy it, test it and listen.
to get them to stick better, you'll want a 45º bevel on the edges
I think at the time, for me at least, I was using a steep slope filter on my crossover and didn't really see the need, as the D2200PH performs so remarkably well for it's price, there was no need to spend almost three times as much, which admittedly, is still not an excessive sum, comparatively. now that I've reached the point where I'm splitting hairs to find improvements, it might make better sense. I'm not about to rush out to get a pair, but my curiosity is piqued. Perhaps after I paint a few more guitars, I'll direct some of the revenue towards them.I recommended this driver last year for the same reasons and you guys about ran me out of the thread lol.
Let's call them horn corners.
Im in the same boat. I have a few guitars to sell, a few more to finish for clients and a couple pro amps to get rid of and I can buy more stuff. I’m also thinking about a bass bin that’s somewhere between a Belle and LaScala in size, but with a tractrix curve for horizontal expansion, as well as a bigger tractrix horn up top, but that’s a long way off. I’ll probably pick up another pair of WG 45-50 if I get the d4500phAlright, I can't stand it anymore... I'm looking to see what I can sell so I can buy one D4500Ph for testing. I told myself that if anything new comes into the basement, something has to depart to maintain my "space". Got plenty to sell, but they are each a labor of love.
So. The difference is measurable, is it perceivable and if so, how would you describe it?Another important difference between the two drivers is the impedance curve. The D2200ph has a massive peak around 500hz...three to four times that of the D4500ph. This needs to be accounted for if using a passive crossover. The plots below detail just that. The red plot is the D2200ph with no filter. The blue plot is using a series 47uf series capacitor. Even though this would be a textbook 400hz first order high pass, the impedance curve results in a 3-4db increase in voltage at 400hz.
All I have is one horn and one driver for measurements. No really good way to listen.So. The difference is measurable, is it perceivable and if so, how would you describe it?
You have a D4500Ph Mike? You sneak...
