A couple of new Toys
sony6060
Banned
Fisher 400 & Fisher X-101C. Both work well so far. Started cleaning up the Fisher 400. I removed the knobs to clean the dial & replace the dial lamps.
Those are nice! Where did you find them?:smoke:
A person had these in CT. Here are better pictures. The Fisher 400 just received new tuner & multiplexer tubes plus a fresh alignment. The 400 sounds great. I also have another.
Fisher 400. Better pix. I think I need a new camera.
Nah! Just don't use so much backlight. The internal meter on the camera will measure the amount of backlighting, compensate for that, and make the front of the gear appear darker (it's either upping the F/stop, or upping the shutter speed or both). Try 2 lamps in front of the gear but off to the sides if it's back lit. That'll even the light/dark out some and bring the 400 out of the dark ages without washing out the rest of it. Or cut down on the back lighting and add a little fill light in front.
I use a 10mpxl KODAK 650 digital. About 1/2 the time I use the manual settings, a couple of lights off to the sides, and no flash.
Larry
