View attachment 710862 View attachment 710863 View attachment 710864 View attachment 710865
Buzz couldn't resist this fun, complicated project.
Here are a couple of photos:
1. I like gluing modern doubler caps with JB weld to the old style phenolic cap spacers. One of the original doubling cap cans contained a 500V cap, which I migrated to the remaining can (I restuffed it with all new caps).
2. I stole the idea of installing 3-way binding posts on the two speaker terminals that I plan to use (i.e. 8 ohm and common);
3. I don't guess you can see it very well, but I simplified the Tape Head / Phono Hi / Phono Low input terminal strip into one RCA plug for MM phono only;
4. I had some reservations about drilling down into & removing the long terminal strip connecting to the bias and phase pots (the drill's torque forces can make a mess of things) so I decided to mount the three pots on a bracket. It's a lot more accessible that way, and it leaves LOTS of space for the 24V tranny & other stuff below.
More later, if Dave doesn't strangle me first . . .
And the little things.
Those bias/phase controls look to have the about same color plastic as the front panel push buttons.
I got to figure its not a coincidence knowing you Jon.
One of the things I appreciate the most about you Jon is your extreme attention to detail.
Frannie
