A little help from my friends - What is this??
Mcawber
Hey guys, can anybody tell me if they recognize this Garrard model? How about the wooden tonearm? Thanks.
Yep, that's it. Thanks guys. This thing is a wreck. I'm missing the center pin, it's filthy dirty, and there's no bottom cover. All the gears and motor etc...are exposed underneath. The one good thing I did find however is that the platter spins quitely and forever with a very slight push. I'm going to try to restore this. I know nothing about it, so any advice would be appreciated.
Thanks
Thanks
There was no bottom cover on this, at least on the one I had anyways. I seem to recall 2 spindles with this unit, 1 short and 1 changer style. I will have a look around my garage as I may still have the changer one.
EDIT* Sorry, No Luck on spindle.
No problem dnpainting....thanks for looking. I'm going to snap some photos of the underneath tomorrow and put them up. I'm not sure if everyything's there. I know this was a changer, but there's no changer arm.
When you say "changer arm" do you mean the arm that swings over on the old consoles? These would not have had that. They just had an optional changer spindle that allowed one record to drop at a time.
Regarding the bottom cover, as dnpainting mentioned I think most tables of the era did not have bottom covers. None of my Duals or Miracords do anyway.
Edit: come to think about it, I think I've got a Lab-80 in somewhat unique Altec all-in-one stereo. All the levers in the TT are frozen (grease hardened) to the point that I don't think mine is worth resurrecting. I'll see if I happen to still have the spindles.
cubby: Some alcohol, Qtips and time should "unfreeze" the controls. It's worth resurrecting. Relube with White lithium grease.
Larry
