The first two items on this thread is what I'd like to accomplish.1. Standard Restoration Work &What are you wanting to restore? There is always the option of shopping the parts yourself on mouser or digikey. That way you know you're getting quality parts.
I 2nd that McShane should be contacted to get the parts kit list for the 400.The first two items on this thread is what I'd like to accomplish.1. Standard Restoration Work &
2. Basic Modification Package. I'd order from Mouser if I could trust myself to not screw it up - which is why I was asking if anyone had a BoM for this. I know I need to redo the power supply. I can hear it. I believe I need to work on the phono stage, too, because it doesn't seem to give me anything but a loud hum. I'll email McShane and see if he can set me up. Thanks.
That’s all I needed. Thank you. Onward!Empirical Data point. I have 2 400's (one early and one late), 2 800c's (1 10000 series for the '63 Executive and a standalone 35000 series) and a Sansui 1000A all using either EH7591's, Tungsol Re-Issue 7591's or in the case of the 400's EH 7868's. In all 5 I've put in Dave's recommended 100Ω screen stab resistors for the last 10 years. I've rebuilt at least 11 400's, a few other 800c's an all got the 100Ω resistors. No failures, no problems. With original tubes, it's your decision. But I'd read Dave's article here......http://www.tronola.com/Gillespie2544.pdf. and use your own judgement.
A CL80 will get very hot. It is soaking up amperage. If you believe (and some better qualified can chime in) that it's too hot, perhaps you have an amperage issue. Depending on where you put the CL80, check voltages in the circuit preceding the CL80 to ensure your voltages are normal per the schematic.
